Flat panel monitor
The industrial 12.1-inch SVGA flat panel monitor is specifically designed for industrial or commercial applications. The LCD backlight has a life expectancy of 50,000 hours. The front panel is made of aluminum, NEMA4/IP65 compliant and the hard anodic coating protects the panel from abrasion and acid corrosion.
The industrial 12.1-inch SVGA flat panel monitor is specifically designed for industrial or commercial applications. The LCD backlight has a life expectancy of 50,000 hours. The front panel is made of aluminum, NEMA4/IP65 compliant and the hard anodic coating protects the panel from abrasion and acid corrosion. The direct-VGA signal transmission allows a regular VGA control card to be used. Other features include a resolution of up to 800 x 600, a multi-scan function supporting XGA, SVGA, VGA and text mode; auto-recognition of input signal; VESA arm; and desktop, panel and wall mounting capability. Both resistive and capacitive touch screens are available.
Advantech
www.eautomationpro.com/us
