Explosion-proof receptacles
The 7/8-16UN minifast explosion-proof feed-through two to six-wire receptacles provide a safe and efficient way to implement explosion-proof protection in Class I, Division 2 hazardous areas for all industries. The feed-through installs directly in standard conduit entries in explosion-proof enclosures without requiring a poured seal, conduit or extensive wiring. An incorporated minifast quick-disconnect eliminates field terminations and is compatible with the company’s FM approved cordsets.
The feed-through is fully potted with a force-resistant compound tested to 9,000 psi; exceeding FM requirements by 50%. The high-quality, 316 stainless steel housing and keyed connector eliminate incorrect wiring and accommodates standard power in hazardous locations. These connectors provide NEMA 1, 3, 4, 6P and IEC IP67 protection.
TURCK
www.turck.com
