Explosion-proof momentary push button switch
Larson Electronics' EPS-2XPB-SG-MS is designed for controlling machinery or process in industrial and commercial applications and is explosion-proof.
By Larson Electronics March 18, 2016
Larson Electronics’s EPS-2XPB-SG-MS ten amp explosion-proof momentary push button switch is designed for controlling machinery or process in industrial and commercial applications. The explosion-proof momentary switch is Class 1 Division 1 & 2 and Class 2 Division 1 & 2 rated for hazardous locations. This start/stop push button switch is constructed for heavy duty use and is factory sealed, eliminating the need for added seal fittings and compound. The switch is enclosed in a separate sealing chamber which has smooth, double flanges that mate both to the cover and the mounting enclosure to provide flame tight joints. The housing for this explosion proof switch is made of a malleable iron body with a cast copper free aluminum alloy cover, epoxy powder coated for a natural finish. This switch can be used in applications such as chemical plants, oil and gas refineries, gas loading terminals, grain elevators, and metal handling or finishing areas where the atmosphere may contain hazardous gases and dusts.
Larson Electronics
www.larsonelectronics.com
– Edited by CFE Media. See more Control Engineering HMI and operator interface products.
