Explosion- and flame-proof coil enclosure
These explosion and flame-Proof 316L coil enclosures are used for 2-Way and 3-Way valves in the oil and gas industry.
The 316L stainless steel explosion-proof coil and enclosure are used for the control of process flows and actuator pilot control. It is designed for severe duty applications in the control of solenoid valves in hazardous areas (zone 1-21) such as found in oil and gas, waste water treatment, chemical and pharmaceutical processing, power generation, pulp and paper, and other process industries. 316L stainless steel pneumatic pilot valves and coil enclosures allow the coil field to be rotated 360 degrees and flipped 180 degrees relative to the valve for ease of piping and electrical connections.
Parker
www.parker.com
