Expansion of the M12 X-coded product family
Binder has expanded its M12 X-coded product family with new receptacles, cordsets and feed-through connectors.
By Binder-USA July 4, 2016
Binder has expanded its M12 X-coded product family with new receptacles, cordsets and feed-through connectors. The X-coded products meet CAT6A specifications with data transmission rates up to 10 Gbps. These high-speed connectors are designed for industrial communications and networks, video surveillance and other applications requiring a fast reliable Ethernet connection. The M12 X-coded products include male and female receptacles with dip solder angled contacts. This allows more versatility when designing panels and mounting the connector to a board. The product family has a male to female jumper cordset in addition to the existing male to male cordset. They feature a feed-through connector when needing a pass through the panel solution.
Binder-USA, LP
www.binder-usa.com
