Electronic overload relay
The C396 electronic overload relay can be used as a stand-alone, panel-mounted device or directly mounted to an IEC, NEMA or DP-rated contactor. The self-powered overload includes phase-loss and imbalance protection, a 5:1 adjustment range, selectable trip class (5, 10, 20, 30), selectable manual/automatic reset, visible trip indication, 6-G vibration rating, 15-G shock rating and remote reset.
By Plant Engineering Staff November 15, 2007
The C396 electronic overload relay can be used as a stand-alone, panel-mounted device or directly mounted to an IEC, NEMA or DP-rated contactor. The self-powered overload includes phase-loss and imbalance protection, a 5:1 adjustment range, selectable trip class (5, 10, 20, 30), selectable manual/automatic reset, visible trip indication, 6-G vibration rating, 15-G shock rating and remote reset. Other features include a tamper-proof cover and an FLA setting dial. It’s RoHS certified and uses 95% less power than electromechanical relays.
Eaton Corp. : www.eaton.com
