Electromagnetic flowmeter for concrete batching applications
Badger Meter's M7600 electromagnetic flowmeter is designed to provide a measurement solution for use in a wide range of concrete batching applications.
By Badger Meter May 25, 2016
Badger Meter's M7600 electromagnetic flowmeter is designed to provide a measurement solution for use in a wide range of concrete batching applications. Courtesy: Badger MeterBadger Meter’s M7600 electromagnetic flowmeter is designed to provide a measurement solution for use in a wide range of concrete batching applications. The M7600 electromagnetic flowmeter achieves an accuracy of ±0.5% of rate for velocities greater than 1.64 ft/s and ± 0.008 ft/s for flow rates less than 1.64 ft/s with a repeatability of ±0.1%. Its rugged design ensures exceptional reliability in demanding environments. The meter features a non-intrusive open flow tube that virtually eliminates pressure loss, and with no moving parts to impede the flow stream, maintenance is kept to a minimum—even in less than ideal fluid conditions. The M7600 is a metering device for clean or reclaimed water batching in ready mix, precast, prestress, and block plants, and requires minimal maintenance over a long operating period. Reliable and accurate flow measurement in concrete batching enables companies to control material costs and ensure optimal finished product quality.
Badger Meter
www.badgermeter.com
– Edited by CFE Media. See more Control Engineering process sensor and actuator products.
