Electrical
By Staff July 1, 2005
Intelligent energy management
ION 7550 RTU option converts the ION 7550 energy meter into a highly effective solution for combined metering of utilities such as water, air, gas, electricity and steam. Using multiple I/O points and Modbus Master support, the meter inputs pulses, analog signals and data from other meters and transducers. Data and sequence-of-events logging, GPS time synchronization and Web-enabled communications options allow the unit to operate as a data concentrator for collecting, storing and delivering information over public or private networks to energy management or automation systems for later analysis.
Power Measurement www.pwrm.com Write 313 on PE card
Lock-out relays
Lock-Out Relays protect critical electrical equipment in utilities and plants. Models include manual-, electric-, or self-reset types. Manual reset types are reset by the operator moving the handle back to normal and have nominal trip speeds less than 8 milliseconds at rated voltage. Electric-reset models can be reset either manually or through a command from a supervisory control. Self-reset units reset automatically once the trip has been cleared. Reset is either instant or according to a factory-set time delay.
Electroswitch www.electroswitch.com Write 314 on PE card
