Electrical
By Staff May 10, 2004
Circuit monitors
PowerLogic 3000 and 4000 series circuit monitors have been reengineered to include wave shape analysis and disturbance alarm data. Disturbance detection feature characterizes disturbances as upstream or downstream with a confidence indication displayed in an active alarm window, onboard event log, email, or error checking/correction html page.
Schneider Electric us.squared.com Write 307 on PE card
Inverter/PLC combo
The 3G3MV-P10CDT-E onboard PLC installs directly on an Omron 3G3MV inverter to provide intelligence and autonomy for tasks such as positioning and synchronization. The combination of PLC and inverter eliminates the cost and delay of point-to-point wiring and saves panel space. A direct, dual-port RAM connection provides access to inverter parameters; encoder and interrupt inputs; and digital, pulse, and PWM outputs.
Omron Electronics LLC omron.com Write 308 on PE card
Modular switchgear
PMX modular metal-enclosed switchgear is available with 600-A continuous current bus and up to 25-kA short-circuit interrupting capability. Any number of modules can be joined together by means of bus through-bushings. Switchgear can be furnished for common-bus source transfer and remote supervisory applications.
S&C Electric Co. sandc.com Write 309 on PE card
Plug and receptacle
DS100C switch-rated 100-A Decontactor series plug and receptacle function as a line-of-site disconnect switch, allowing users to make and break motor connections under full load. The front shutter prevents user access to live parts.
Meltric Corp. meltric.com Write 310 on PE card
