Ejector venturi for tough process and high concentration emergency gas scrubbing
Bionomic's series 6500 jet venturi scrubber is designed to simultaneously remove gaseous contaminant and particulate down to .75 micron size for chemical, pharmaceutical, and other scrubbing applications.
Bionomic Industries’ series 6500 jet venturi scrubber offers improvements in operating performance and reliability. The Bionomic series 6500 has availability of a proprietary multi-spray zone staging configuration that gives up to a 50% boost in collection efficiency performance. The scrubber features a design that utilizes a high velocity spray and scrubbing liquid flow to achieve simultaneous removal of gaseous contaminants and particulate down to .75 micron size. The series 6500, with its high scrubbing liquid to gas ratio, is also the ideal design for rapidly reducing the temperature of high exothermic reactive gases or to condense steam. Designed to provide near infinite turndown capability, the series 6500 creates its own draft to eliminate the need for a fan in most cases—simplifying the system and related costs. Depending on the application and needed removal efficiency the series 6500 is offered as a stand-alone device, with the addition of the proprietary multi-spray zone staging addition as well as a final polishing packed tower complimented by a full range of mist eliminator and sump tank capacities. Achievable removal efficiencies are over 99.9% and gas capacity sizes from 5 through 60,000 acfm are standard. Typical applications include: removal of gaseous and/or particulate emissions from process reactors and tanks in the chemical and pharmaceutical industries; as an emergency scrubber for ammonia and chlorine gas cylinder storage rooms, fume emissions from laboratory hoods and filling operations; scrubbing explosive or hazardous gases prohibiting presence of air or oxygen including syngas; lime slaker dust and NCG gases in the pulp and paper industry; ceramics manufacturing slip dust from material handling operations and an almost endless number of other applications.
Bionomic Industries
