Ductless Minisplit Heat Pump System by Bosch
The Ductless Minisplit System has separate indoor and outdoor units and only requires a 3-inch diameter opening through a wall to run the drain pipe.
The Ductless Minisplit System has separate indoor and outdoor units and only requires a 3-inch diameter opening through a wall to run the drain pipe. In multi-zone systems, one condensing section can connect to up to five indoor air handlers for individual control in different rooms.
Bosch
View this product at the New Products for Engineers Database.
Original content can be found at gspplatform.cfemedia.com.
