Dual channel CompactFlash
The Dual Channel line of CompactFlash (CF) cards is designed for speed, durability and extended temperature operation. The CF cards are ideal for high performance embedded systems applications requiring high reliability and high tolerance to shock, vibration, humidity and altitude, as well as -40 C to 85 C temperature operation.
The Dual Channel line of CompactFlash (CF) cards is designed for speed, durability and extended temperature operation. The CF cards are ideal for high performance embedded systems applications requiring high reliability and high tolerance to shock, vibration, humidity and altitude, as well as -40 C to 85 C temperature operation. Five storage sizes are available from 1GB to 16GB. The brain of the memory module is a 32-bit RISC controller. The RoHS-compliant CF cards support a dual 3.3 V and 5 V interface.
WinSystems www.winsystems.com
