Draw bar cover
The Milling Machine Draw Bar Cover is designed to protect vertical mill workers from rotating shafts seven feet or less from the floor or working platform.
The Milling Machine Draw Bar Cover is designed to protect vertical mill workers from rotating shafts seven feet or less from the floor or working platform. It guards the turning draw bar with a non-rotating, smooth, welded-steel enclosure, secured firmly to the mill with a powerful ring magnet and safety anchor chain. Simple to install, the draw bar cover prevents clothing, hair or hands from being grabbed by the moving shaft. This product can be used on any vertical mill that has up to a 7-ft. extrusion.
Rockford Systems, LLC
