Drain cleaner
The K-39-AF drain gun has been redesigned with Advanced Feed, a two-way Autofeed feature that allows users to reverse the direction of cable quickly and easily. Designed to push through obstructions quickly, it has a lightweight and better-balanced construction than its predecessor. Weighing in at 11 pounds, the unit's ergonomic design has a new trigger-hand guard to protect users' fingers from...
By Staff November 1, 2006
The K-39-AF drain gun has been redesigned with Advanced Feed, a two-way Autofeed feature that allows users to reverse the direction of cable quickly and easily. Designed to push through obstructions quickly, it has a lightweight and better-balanced construction than its predecessor. Weighing in at 11 pounds, the unit’s ergonomic design has a new trigger-hand guard to protect users’ fingers from the spinning drum.
Ridge Tool Co. : www.ridgid.com
