Drain cleaner
Heavy-duty K-400 drain cleaner features a portable design with a fully-integrated wheeled cart design.
By Staff June 21, 2007
Heavy-duty K-400 drain cleaner features a portable design with a fully-integrated wheeled cart design. Its integrated stair-climbing frame design helps transport the machine up and down stairs, and a built-in telescoping handle provides ease of use. The handle retracts to a low position for easy, compact storage and added stability during operation. The K-400 has a 1/3-hp motor, which spins cable at 190 RPM. The motor is positioned above the drum to improve stability and balance, along with added leg clearance during transport. The drum is supported in both the back and front to reduce machine vibration and increase support. Ridge Tool Co. www.ridgid.com
