Data interface ports
Intersafe is a line of data interface ports that allow programmers to gain access to data without opening the enclosure door. This provides a solution to the NFPA 70E directive on arc flash protection. The door opens to 180 degrees for easy data access and features a 120 Vac duplex receptacle, an Ethernet port and a 5 A circuit breaker.
By Staff November 1, 2005
Intersafe is a line of data interface ports that allow programmers to gain access to data without opening the enclosure door. This provides a solution to the NFPA 70E directive on arc flash protection. The door opens to 180 degrees for easy data access and features a 120 Vac duplex receptacle, an Ethernet port and a 5 A circuit breaker. Hoffman : www.hoffmanonline.com
TO VOTE, WRITE 40 ON THE BALLOT
For more information, write 40 on the card
