Data center air conditioner
The InfraStruXure InRow RP places cooling immediately adjacent to heat sources in small computer rooms and data centers, and can support power densities up to 70 kW per rack when used with hot-air containment systems. Available in both chilled-water and refrigerant-based designs, the unit has an integrated humidifier to provide room-level moisture control.
By Plant Engineering Staff November 15, 2007
The InfraStruXure InRow RP places cooling immediately adjacent to heat sources in small computer rooms and data centers, and can support power densities up to 70 kW per rack when used with hot-air containment systems. Available in both chilled-water and refrigerant-based designs, the unit has an integrated humidifier to provide room-level moisture control. A dedicated dehumidification cycle provides additional moisture control; a standard reheat coil prevents overcooling. A patent-pending control algorithm enables real-time capacity monitoring.
American Power Conversion Corp. : www.apc.com
