Cycling air dryers
By Plant Engineering Staff April 20, 2007
The refrigerated dryer series is now available for flows from 20 to 885 scfm, in pressures up to 230 psig. The cycling dryers provide efficiency by using a thermal mass medium for storage and operating the refrigerant compressor only when necessary. An air-to-air heat exchanger reduces the load on the refrigeration system by pre-cooling the inlet air. The dryer design facilitates access to all components and minimizes the required floor space. Standard features include simple controls, a stainless-steel separator and an electric demand drain.
Kaeser Compressors www.kaeser.com/cleanair
