Current output displacement transmitters
These displacement transmitters have improved IP67-rated sealing coupled with polymer guides with rigid carriers.
By Plant Engineering Staff June 27, 2007
LD630 displacement transmitters have improved IP67-rated sealing coupled with polymer guides with rigid carriers. The transmitters have a less than 0.2% linearity as well as rugged stainless steel body construction making them especially accurate and reliable in wet and corrosive conditions. Output options are either direct-acting 4-20 mA or reverse-acting 20-4mA. The transmitter is recommended for industrial use and automotive testing applications.
Omega Engineering
www.omega.com
