Coupling guard for ANSI/ISO pumps
Type PCG pump coupling guards are made specifically for ANSI and ISO pump connections. The guard has trim & fit convenience, low initial cost, safety compliance, simplified installation and reduced maintenance. The guard is simply trimmed to length and attached to the foundation with four fasteners.
Type PCG pump coupling guards are made specifically for ANSI and ISO pump connections. The guard has trim & fit convenience, low initial cost, safety compliance, simplified installation and reduced maintenance. The guard is simply trimmed to length and attached to the foundation with four fasteners. A pump side end cap is supplied to enclose the extension opening, which can be fitted around the pump seal cage. Rexnord Industries : www.rexnord.com
TO VOTE, WRITE 82 ON BALLOT
For more information, write 82 on card
