Corrosion-resistant pressure switches
This line of pressure switches has been enhanced to be more corrosion-resistant and environmentally friendly, featuring RoHS-compliant Chromate 3 plating, which reduces the potential for corrosion and rust.
The Square D brand Pumptrol 9013 pressure switch line hasbeen enhanced to be more corrosion-resistant and environmentally friendly,featuring RoHS-compliant Chromate 3 plating, which reduces the potential forcorrosion and rust. The new plating covers all metal parts, protecting theswitch’s key mechanical components. The diaphragm is manufactured to U.S Food& Drug Administration specification CFR 177.2600, making the switchescertified for potable (drinking) water systems, while meeting lead contentrestrictions for plumbing fixtures.
Other enhancements include indentations just above the
ground screws, which provide a more secure grounding method. Each switch
contains a sturdy plastic hole plug to keep insects, debris and other
contaminants out. Also, 80% of the components in every switch are manufactured
in the U.S.
to strictquality standards.
Schneider Electric
www.schneider-electric.us
www.Pumptrol.com
