Coriolis mass flowmeter for chemical, oil and gas applications
Krohne's Optimass 6400 is a twin bent tube Coriolis mass flowmeter designed for standard liquid and gas applications in chemical and petrochemical and oil and gas industries and can operate in extreme heat and cold conditions.
By Krohne, Inc. October 21, 2015
Krohne’s Optimass 6400 is a twin bent tube Coriolis mass flowmeter designed for liquid and gas applications in the chemical and petrochemical, oil and gas, pharmaceutical, food and beverage, and energy and power industries. The Optimass 6400 has a signal converter with advanced device and process diagnostics, compliant to NAMUR NE 107. The Optimass 6400 has been approved for custody transfers of liquids and gases, said to be ideal for process industries and specialist applications like LNG, CNG, or supercritical gases in terminal or storage/bunkering, along with custody transfer applications.
The Optimass 6400 also features advanced entrained gas management (EGM), with no loss of measurement with gas entrainment up to 100% of volume. The Optimass 6400 with EGM can follow and correct for the varying amplitudes. Available in a range of sizes from DN 08 to 250, the Optimass 6400 is offered in stainless steel 316L, Hastelloy C22 and Duplex steel UNS S31803. It is also designed to operate in high temperatures up to 752 F (400 C), as well as cryogenic applications down to -328 F (-200 C).
Krohne Inc.
www.us.krohne.com
– Edited by CFE Media. See more Control Engineering process sensor and actuator products.
