Cooling tower vacuum filter
CTV-F2 filtration system is designed to work in situations where cooling tower water needs to be cleaned, filtered and returned to the basin. This unit can handle the high flow and small micron filtration requirements when cleaning a cooling tower. A pair of reusable filter cartridges allows an operator to clean cooling tower water down to 5 microns.
CTV-F2 filtration system is designed to work in situations where cooling tower water needs to be cleaned, filtered and returned to the basin. This unit can handle the high flow and small micron filtration requirements when cleaning a cooling tower. A pair of reusable filter cartridges allows an operator to clean cooling tower water down to 5 microns. Quick lock lids allow fast filter changes. Goodway Technologies Corp., Building Maintenance Group : www.goodway.com
