Cooling tower requires no field assembly
Premier induced-draft counterflow cooling tower is available in seven models with 250-500 tons of capacity. The polyethylene shells are corrosion proof, maintenance free, and rotationally molded in a one-piece seamless structure.
Premier induced-draft counterflow cooling tower is available in seven models with 250-500 tons of capacity. The polyethylene shells are corrosion proof, maintenance free, and rotationally molded in a one-piece seamless structure. The towers are completely factory assembled. Delta Cooling Towers, Inc.
