Connector system for limited spacing
The SpeedStack Mezzanine Connector System supports data rates of up to 40 Gbps and is designed for OEMs that contend with limited PCB real estate.
The SpeedStack Mezzanine Connector System is a high-density, low-profile solution that supports data rates of up to 40 Gbps per differential pair. The system is designed for OEMs that contend with limited PCB real estate. The mated stack heights of 4.00 to 10.00mm along with a 0.80mm pitch provides design engineers with the ultimate in flexibly to address space constraints without sacrificing performance. The SpeedStack Connector System comes in multiple circuit sizes of 22, 44, 60, 82, 104 and 120 with a range of 6 – 32 differential pairs for even greater flexibility.
Molex
