Condenser stops vapor emissions
TV Series condensers are available for flows up to 5000 scfm and for pressure from full vacuum to 50 psig. Using condensers to cool vapors at storage tanks and reactor vents is an economical way to control many VOC emissions.
TV Series condensers are available for flows up to 5000 scfm and for pressure from full vacuum to 50 psig. Using condensers to cool vapors at storage tanks and reactor vents is an economical way to control many VOC emissions. Designs are compact and have a pressure drop less than 0.02 psi. The extended heat transfer surface enables small units to perform substantial condensing duties.
Xchanger, Inc.
www.xchanger.com
Circle 391
