Condensate pump designed for long life cycles
Pivotrol pressure powered condensate pump is engineered for dependable steam system condensate recovery in rapid-cycling process environments and under all pressure and temperature conditions. The pump mechanism replaces pins and linkages with pivots, which reduce friction and wear, lengthening service life.
By Staff November 1, 2005
Pivotrol pressure powered condensate pump is engineered for dependable steam system condensate recovery in rapid-cycling process environments and under all pressure and temperature conditions. The pump mechanism replaces pins and linkages with pivots, which reduce friction and wear, lengthening service life. A special damper uses hydraulic inertia of the collected condensate to reduce mechanical shock as valve actuators shift. Spirax Sarco, Inc. : www.spiraxsarco.com/us
TO VOTE, WRITE 06 ON BALLOT
For more information, write 06 on card
