Compressed Air – 2000-11-01
Two-stage air compressor is oil-free KNW Series is the world's only oil-free, two-stage, rotary screw air compressor in 20, 25, 30, and 40-hp sizes. It is available in air and water-cooled versions.
By Staff November 1, 2000
KNW Series is the world’s only oil-free, two-stage, rotary screw air compressor in 20, 25, 30, and 40-hp sizes. It is available in air and water-cooled versions. The unit features stainless steel air and oil seals, prelubricated gears and bearings, and PLC microprocessor/controller that displays operating conditions and shutdown messages. Kobelco Compressors America/Rogers Machinery Co.; www.knw-series.com
&READERSERVICE>TO VOTE, WRITE 2 ON BALLOT&/READERSERVICE>
&READERSERVICE>For more information, circle 2 on card&/READERSERVICE>
Compressor controls retrofit to all makes
Flexible, microprocessor-based air compressor controls retrofit to any manufacturer’s product and provide seamless communi-cation over a CAN-based network. It can also communicate to other microprocessor devices that support MODBUS communications for purposes of data collection and availability from a single source. Mottley Enterprises Div., Maxx Controls; www.mottley.com
&READERSERVICE>TO VOTE, WRITE 13 ON BALLOT&/READERSERVICE>
&READERSERVICE>For more information, circle 13 on card&/READERSERVICE>
Air filter monitor determines element replacement
Filter monitor audits compressed air filters for energy savings by determining the optimal time for element replacement. Through microprocessor monitoring, particulate loading of the filter element is continuously audited based on instantaneous and average daily pressure drop measurements. A 60-day advance notice is given prior to the optimal change-out day. Hankison Intl.; www.hankisonintl.com
&READERSERVICE>TO VOTE, WRITE 16 ON BALLOT&/READERSERVICE>
&READERSERVICE>For more information, circle 16 on card&/READERSERVICE>
Air pressure control saves energy
Pressure control system precisely regulates the low-side compressed air pressure to a field adjustable set point, saving energy costs. A visual indicator and set point pressure display make it simple to set the desired downstream pressure. The display adjusts air pressure automatically to within 2 psig of the desired setting. Air/Tak, Inc.; www.airtak.com
&READERSERVICE>TO VOTE, WRITE 46 ON BALLOT&/READERSERVICE>
&READERSERVICE>For more information, circle 46 on card&/READERSERVICE>
Air dryer ensures precise dew point
Cirrus refrigerated air dryer uses a direct expansion circuit to ensure precise dew points. It includes innovative features that significantly reduce full load power consumption. The dryer cycles in stand-by when fitted with an electronic controller, offering cycling dryer savings without compromising the dew point. domnick hunter, inc.; www.domnickhunter.com
&READERSERVICE>TO VOTE, WRITE 68 ON BALLOT&/READERSERVICE>
&READERSERVICE>For more information, circle 68 on card&/READERSERVICE>
Compressed air source is self-contained
Genesis air station consists of a heavy-duty, rotary air compressor, refrigerated dryer, filtration package, and microprocessor control encapsulated in a sound-attenuated enclosure and tank-mounted. All components are in the package, so installation and maintenance are quick and easy. Units area available in three sizes: 71/2, 10, and 15 hp. ABAC/American IMC, Inc.; www.abacamerican.com
&READERSERVICE>TO VOTE, WRITE 74 ON BALLOT&/READERSERVICE>
&READERSERVICE>For more information, circle 74 on card&/READERSERVICE>
Compressed air drain only expels condensate
Eco-Drain removes water from compressed air filters with a capacitance sensor. The sensor has no moving parts and allows the drain to open only when needed, expelling condensate but not valuable compressed air. The robust aluminum housing and superior construction ensure many years of reliable service in harsh environments. Kaeser Compressors; www.kaeser.com
&READERSERVICE>TO VOTE, WRITE 127 ON BALLOT&/READERSERVICE>
&READERSERVICE>For more information, circle 127 on card&/READERSERVICE>
Air compressor installs anywhere
QSD air-cooled, oil-free, two-stage rotary screw air compressor offers the flexibility to be installed in any environment. The air-cooled machine saves operating costs by not requiring cooling water. Exclusive lift valves eliminate the inlet valve on the compressor, reducing maintenance and providing the lowest unloaded power in the industry. Quincy Compressor Div., BFGoodrich; wwwquincycompressor.com
&READERSERVICE>TO VOTE, WRITE 184 ON BALLOT&/READERSERVICE>
&READERSERVICE>For more information, circle 184 on card&/READERSERVICE>
Controller improves air dryer performance
Z-Trol air treatment controller provides up-to-the-minute operating information and allows dryer performance adjustment through microprocessor technology. An option provides enhanced dryer monitoring and expanded performance adjustment capability. Performance adjustment capability allows operating cost savings to be optimized via site-specific settings. Zeks Compressed Air Solutions; www.zeks.com
&READERSERVICE>TO VOTE, WRITE 195 ON BALLOT&/READERSERVICE>
&READERSERVICE>For more information, circle 195 on card&/READERSERVICE>
Air filter provides easy maintenance
Filter 2000 has a three-piece construction that allows easy maintenance and accessibility. The element design provides superior performance and low pressure drop. It is available in four filtration grades. A simple push safely checks the autodrain and depressurizes the bowl. A differential pressure indicator checks filter condition. Air Solutions Group, Ingersoll-Rand Co.; www.ingersoll-rand.com
TO VOTE, WRITE 211 ON BALLOT
&READERSERVICE>For more information, circle 211 on card&/READERSERVICE>
