Component coating
Kerkote TFE coating reduces friction in the company's lead screw, linear rail, spline shaft, slide, guide and actuator assemblies. The coating is a long-term dry lubricant that transfers to the nut, creating a low friction protective layer on the nut or bushing without harboring additional dirt and debris.
Kerkote TFE coating reduces friction in the company’s lead screw, linear rail, spline shaft, slide, guide and actuator assemblies. The coating is a long-term dry lubricant that transfers to the nut, creating a low friction protective layer on the nut or bushing without harboring additional dirt and debris. No additional lubrication or maintenance is required, and the coating can reduce erratic drag torques and unpredictable wear.
Kerk Motion Products Inc.
www.kerkmotion.com
