Compact extruded body cylinders
The NITRA Pneumatics H-Series compact extruded body cylinders are designed for fittings to be mounted in the top of the cylinder to meet a broad range of limited-space applications.
By AutomationDirect April 13, 2016
The NITRA Pneumatics H-Series compact extruded body cylinders are designed for fittings to be mounted in the top of the cylinder to meet a broad range of limited-space applications. Courtesy: AutomationDirectThe NITRA Pneumatics H-Series compact extruded body cylinders are designed for fittings to be mounted in the top of the cylinder to meet a broad range of limited-space applications. The cylinder bodies and end caps are constructed with hard anodized extruded aluminum and are factory lubricated for optimum performance and long, reliable life. Designed for fittings to be mounted in the top of the cylinder, additional features include a magnetic piston, chrome-plated steel piston rods, and slots for mounting 4mm square cylinder switches.
AutomationDirect
www.automationdirect.com
