Compact CNC platform
The IndraMotion MTX compact is a CNC solution for high-production machining centers, handling systems or simple auxiliary units. It provides high performance in a small footprint while improving machine cycle times and part quality. Capable of controlling up to eight axes in two NC channels with an IndraLogic PLC, it can process up to 200 NC blocks per second and has a 30-block look-ahead rate ...
The IndraMotion MTX compact is a CNC solution for high-production machining centers, handling systems or simple auxiliary units. It provides high performance in a small footprint while improving machine cycle times and part quality. Capable of controlling up to eight axes in two NC channels with an IndraLogic PLC, it can process up to 200 NC blocks per second and has a 30-block look-ahead rate to achieve shorter machine cycle times. Like other MTX versions, the compact version can be used for milling, turning, grinding, automation and other applications with up to four-axis simultaneous interpolation. The system provides scalable performance and functionality with open system architecture.
Bosch Rexroth AG
www.boschrexroth-us.com
