Communications gateway
The multi-protocol communications gateway for steam-to-water and water-to-water heaters features a plug-n-play package that supports integration with N2, BACnet and LonWorks systems to deliver up to 300 user-selected data points.
By Plant Engineering Staff March 15, 2008
The multi-protocol communications gateway for steam-to-water and water-to-water heaters features a plug-n-play package that supports integration with N2, BACnet and LonWorks systems to deliver up to 300 user-selected data points. The gateway’s package is a UL-recognized plastic enclosure, capable of installation on a wall or mounted using a steel bracket. Inside the package resides all three protocols, and the standard gateway is programmed for up to 12 boilers/heaters, four ECS units and one BMS.
Aerco International Inc.
www.aerco.com
