Coating applies direct to rust and metal
9800 Urethane Mastic System is designed for application direct to sound rust, metal, and primed surfaces with minimal surface preparation. Easy to apply by brush, roller, or spray, the product cures at temperatures as low as 40 deg F.
9800 Urethane Mastic System is designed for application direct to sound rust, metal, and primed surfaces with minimal surface preparation. Easy to apply by brush, roller, or spray, the product cures at temperatures as low as 40 deg F. A second coat can be applied over the still-wet first coat to help reduce downtime. The low-VOC coatings do not require thinning and feature a pre-measured base and activator package for easy mixing. Rust-Oleum Corp., www.rustoleum.com
Circle 407
