B&R and Cognex cooperate on POWERLINK
B&R and Cognex pair up to offer a complete solution which incorporates visualization, control, drive technology for precise product monitoring in production lines.
Cognex and B&R have entered a technological cooperation: their strategic goal is the use of POWERLINK in the In-Sight line of products from Cognex. "The result of this cooperation is a complete solution that incorporates visualization, control and drive technology for high-speed and high-precision product monitoring in production line operation. The Cognex In-Sight product line is optimally integrated in the B&R System via POWERLINK," said Hans Wimmer, B&R Managing Director.
Cost-efficient and modular
Machine manufacturers will benefit not only from synchronization of Cognex In-Sight products and the B&R control system, they will also benefit from reportedly easy integration of a wide range of machine designs. The new vision solution is also compatible with all POWERLINK-based B&R product lines.
The Cognex image processing systems for checking, identifying and feeding parts reportedly feature quick start-up times and a significantly reduced amount of wiring. This means considerable savings potential for the machine manufacturer and end-user. Extensive diagnostic options allegedly facilitate smooth operation of the high-resolution application in large-scale production facilities.
www.br-automation.com
B&R Industrial Automation, Inc.
Cognex
– Edited by Gust Gianos, Plant Engineering, www.plantengineering.com
