Blower enclosure
The All-Environment blower enclosure is designed to reduce noise below OSHA standard 26 CFR 1910.95(a), to levels as low as 75 db. The enclosure incorporates gasket seams to prevent water or contaminant intrusion and is adaptable to most vertical centrifugal blowers with a 145T-284T motor frame for NEMA or IEC configurations.
The All-Environment blower enclosure is designed to reduce noise below OSHA standard 26 CFR 1910.95(a), to levels as low as 75 db. The enclosure incorporates gasket seams to prevent water or contaminant intrusion and is adaptable to most vertical centrifugal blowers with a 145T-284T motor frame for NEMA or IEC configurations. The enclosure also features a double-wall, foam-filled polyethylene construction, external filters with a change gauge, a quick-access maintenance door and dual-hinged gas shocks.
Sonic Air Systems, Inc.
www.sonicairsystems.com
