Bellows protect linear guides
Walk-On protective bellows for linear guides maintains long life and reduce or eliminate frequent replacement and maintenance problems caused by abuse.
Walk-On protective bellows for linear guides maintains long life and reduce or eliminate frequent replacement and maintenance problems caused by abuse. The bellows are made from a compliant material, with internal supports, and are designed to be collapsible. They can operate in environments up to 300 F, and offer a compression ratio of approximately 19%.
Thomson Industries, Inc.
www.thomsonindustries.com
