Bandsaw blade
The TRI-TECH CT bandsaw blade, designed for cutting large cross-sections, cuts a variety of materials, including high-strength steel and nickel-based alloys.
By Plant Engineering Staff June 15, 2008
The TRI-TECH CT bandsaw blade, designed for cutting large cross-sections, cuts a variety of materials, including high-strength steel and nickel-based alloys. Its set-style tooth pattern cuts straight and eliminates the pinching that occurs when cutting high stress metals. The proprietary tooth geometry creates three thick chips with each pass, which makes a more productive cut by keeping the blade moving. Available in 14 specifications, the saw ranges in sizes of 1
Lenox
www.lenoxtools.com
