Ball valves
The SK Series of multipurpose ball valves features 316-stainless-steel construction, low-torque operation, spring-loaded seats and a floating ball, which are designed to provide leak-tight integrity in low and high-pressure systems. The valves are available with 5211-compliant rack-and-pinion pneumatic actuators.
By Plant Engineering Staff September 15, 2007
The SK Series of multipurpose ball valves features 316-stainless-steel construction, low-torque operation, spring-loaded seats and a floating ball, which are designed to provide leak-tight integrity in low and high-pressure systems. The valves are available with 5211-compliant rack-and-pinion pneumatic actuators. End-connection choices include readable tube fittings, NPT and ISO pipe and VCO O-ring face seals. The series is available in 1/4 and 3/8-inch sizes and is rated for working pressures up to 6,000 psig (413) bar and temperatures in the range of -40 to 302 degrees F.
Swagelok Co.
www.swagelok.com
