Ball bearing inserts
These set screw type and locking collar type units are stocked in many sizes to fit shafts ranging from ½ inch to 4 inches in diameter. The set screw type bearing inserts have 2 set screws. Tightening the set screws contacts the shaft, which effectively locks the shaft to the bearing so that the two will turn as one.
Quality Bearings &Components , www.qbcbearings.com
