Asset condition management solution
InFusion condition manager provides the ability to collect real-time condition data from a range of plant data sources. It provides tools for analyzing and contextualizing data and applies a rule set that triggers and manages the appropriate operations, engineering or maintenance actions. The solution also balances asset availability and combines plant performance with business objectives and a...
InFusion condition manager provides the ability to collect real-time condition data from a range of plant data sources. It provides tools for analyzing and contextualizing data and applies a rule set that triggers and manages the appropriate operations, engineering or maintenance actions. The solution also balances asset availability and combines plant performance with business objectives and analyzes data gathered from a range of intelligent field devices such as sensors, actuators and rotating and non-rotating equipment such as pumps, motors, compressors, turbines, dryers and heat exchangers.
Invensys Process Systems : www.infusionecs.com
