Anti-vibration mounts
By Plant Engineering Staff February 9, 2007
Heavy-duty M-Series anti-vibration mounts are designed for use with automatic lathes, grinding machines, injection molding machines, drilling and milling machines and similar equipment. The mounts resist fatigue from working cycle times and lateral forces in heavy machinery and are designed for use on machinery that does not require fastening to the floor. They’re designed for use with loads ranging from 100 to 12,000 pounds. A reinforced, built-in leveling bolt support cup distributes machine loads to support points within the mount, and a leveling element provides direct machine mounting to suit most installation needs.
Sunnex
www.sunnexonline.com
