ANSI process pump
The ANSI Model 3196 process pump features i-Frame, an onboard condition monitoring system.
By Plant Engineering Staff December 1, 2008
ANSI process pump
The ANSI Model 3196 process pump features i-Frame, an onboard condition monitoring system. Nested on top of the power end to measure critical vibration and temperature readings, the system activates early warning systems when variations in temperature or vibration exceed preset parameters. Other standard features include severe duty thrust bearings and dual stainless-steel, bronze-bearing isolators. An optimized sump design improves heat transfer and keeps contaminants away from bearings. The pump comes in 29 different sizes to accommodate numerous applications.
ITT Goulds Pumps , www.gouldspumps.com
