Continue to Site
An easy off solution to repair a greasy mess
Plant Engineering brings you another item from the Tips & Tricks archive
By Plant Engineering Staff December 1, 2008
When cleaning or repairing an item crusted with grease, it doesn’t have to sit in solvent for hours to be ready for repair. As Chet White noted in our August 2000 Tips & Tricks issue, the trick is to use oven cleaner on the metal item. Be sure to wear gloves when working with the cleaner, and use it in a well-ventilated area. After a few minutes, the grease wipes away, and you’re ready to start working.
