Air handler
The Envision series air handler is available in 2-and 5-ton capacities. Designed for R-410A refrigerant, the air handler is configurable as either a dx or a hydronic coil. The air handler features a variable-speed fan motor, a field-adjustable, four-position design, a factory-installed thermal expansion valve, a 1-inch filter rack and a corrosion proof stainless steel drain pan.
Water Furnace International, Inc.
