Air filter
The Purafilter – OA is a combination particulate and chemical filter designed for use in high-occupancy commercial environments, in which outdoor air quality is questionable and optimal indoor air quality is a requirement. The unit is designed to replace existing particulate filters, eliminating outside-generated contaminants.
By Staff July 15, 2007
The Purafilter %%MDASSML%% OA is a combination particulate and chemical filter designed for use in high-occupancy commercial environments, in which outdoor air quality is questionable and optimal indoor air quality is a requirement. The unit is designed to replace existing particulate filters, eliminating outside-generated contaminants. It is a key component the Enersave Program, an energy-savings program that reduces the need for outside air by 75% and is based on an interpretation of ASHRAE Standard 62.1-2004.
Purafil, Inc.
www.purafil.com
