Continue to Site
Air compressors
A new series of air compressors from Sullair is designed for point-of-use facility installations. The Sullair 3000 is a 40-hp model; the Sullair 3700 is 50 hp; and the Sullair 4500 is 60 hp. They are designed to make service and routine maintenance faster, simpler and more efficient. All standard compressor maintenance can be performed from one side of the machine, and the compressor's fluid le...
By Staff March 1, 2006
A new series of air compressors from Sullair is designed for point-of-use facility installations. The Sullair 3000 is a 40-hp model; the Sullair 3700 is 50 hp; and the Sullair 4500 is 60 hp. They are designed to make service and routine maintenance faster, simpler and more efficient. All standard compressor maintenance can be performed from one side of the machine, and the compressor’s fluid level can be checked without opening the doors. The series also features a fully-sealed environmental protection pan to capture spills that may occur during servicing. The new compressors use less energy than equivalent models. Based on 24/7 operation, using full load specific power at $0.08 per kW/hr, the Sullair 3700 offers 11.3% energy savings over competitive 50-hp models.
Sullair www.sullair3700.com .
