Active harmonic filtering
The AccuSine PCS+ and AccuSine PFV+ is used for active harmonic filtering and reactive power compensation.
By Schneider Electric July 1, 2015
The AccuSine PCS+ and AccuSine PFV+ is used for active harmonic filtering and reactive power compensation. The AccuSine+™ product family provides a means to mitigate harmonics, reduce process-related voltage fluctuations, and improve electrical equipment operating life and distribution system capacity. The power factor correction of the active filters reduces utility billing while load support and balancing improves process quality.  With digital communications via Modbus RTU or Modbus TCP/IP, AccuSine+ active filters include remote monitoring and operational control. A compact HMI terminal includes a touch screen that integrates Ethernet and includes an alarm function with fault logging for traceability.
Schneider Electric
www.schneider-electric.com
Schneider Electric is a CSIA member as of 7/20/2015
