2012 POY Finalists: Electrical Controls
Finalists in the Electrical Controls category for the Plant Engineering 2012 Product of the Year competition.
By Brittany Merchut November 19, 2012
Cabinet cooler system
The Dual High Temperature Cabinet Cooler Systems purge and cool overheated electrical control panels in harsh environments. The cabinet coolers eliminate high-temperature malfunctions and protect sensitive electronics from hot, dirty locations by keeping electrical enclosures cool with air as cold as 20 F. With high cooling capacity of up to 5,600 Btu/hr, the cabinet coolers are designed for large electrical enclosures and high heat loads. The cabinet cooler applications include variable frequency drives, programmable controllers, industrial computers, motor controls, microprocessors, and robotics.
EXAIR Corporation
Sensing switch and transducer
The ATS Current Sensing Switch and Transducer is a one-piece solution combing a limit alarm with an analog output signal transducer to monitor produced and consumed ac current up to 1,200 A while isolating outputs and input to maximize safety. The rotary switch makes it easy for operators to set the trip point. With an analog signal available at all times, increases or decreases in current can be detected. The switch also provides limit alarm contacts for over- or under-current conditions.
NK Technologies
Want this article on your website? Click here to sign up for a free account in ContentStream® and make that happen.
