Wednesday, September 23, 2015
Maintenance Electrical Mechanical Energy Management Plant Automation Safety
Sponsored Content
Turning Air Compressors into an Energy Source
Authored by compressed air experts Werner Rauer and Michael Camber, Kaeser’s whitepaper, "Turning Air Compressors into an Energy Source," explains how rotary screw compressors can recover up to 96% of the heat generated during compression to significantly lower a facility’s energy costs.
Download the white paper today.
Choosing a Compressor Solely Based on HP could Negatively Impact your Overall Operating Expenses
Plant engineers will often use the rated horsepower to specify their new air compressors, however not all compressors have the same efficiency. Selecting the compressor based on cubic feet per minute (CFM) that the installation requires, will reduce the ongoing operating expenses.
Download the white paper.
The 7 Pitfalls of Oil Skimming White Paper
Abanaki's white paper offers a detailed how-to-guide on the best practices for purchasing an oil skimmer and how to avoid the common mistakes that are made.
Receive your copy now!
Vaisala Calibration Services
How do you stop sensor drift? Learn how, when and why different parameters need consistent calibration to ensure long-term data accuracy.
Valve Positioners Offer Improved Control Valve Performance
The addition of valve positioners has radically changed the way actuated control valves respond within a process control loop. This white paper details many of the advantages of installing and applying a positioner to a basic, pneumatically actuated control valve package.
Troubleshooting VFD Motor System Problems
Maintenance professionals aren't often aware of tools that identify VFD issues that cause motors to fail. This paper highlights two VFD problems that were diagnosed with advanced motor monitoring equipment.
Register to download the white paper.
Keeping the US Mail Moving
This case study explores how predictive maintenance technologies can identify a significant problem on critical assets, evaluate the risk of continued operation and anticipate the repair and parts BEFORE failure occurs.
Download this case study.
