Workstation cranes serve robotic systems
A new line of robotic workstation cranes includes two series. CLR Series is designed with a limited number of moving parts, which minimizes maintenance, and has a capacity of 2000 lb with an 8-ft vertical lift.
A new line of robotic workstation cranes includes two series. CLR Series is designed with a limited number of moving parts, which minimizes maintenance, and has a capacity of 2000 lb with an 8-ft vertical lift. SLR Series uses a scissors construction to allow 20-ft lifts while maximizing headroom. Capacity is 4000 lb.
Gorbel
www.gorbel.com
